Yamaha 200HP 'stuck up'
Lostinbahrain
Hi there,
New boat owner and have an old 19ft with Yamaha 200HP V6.
I have just had the tilt trim repaired as fluid was leaking from one of the end cap seals.
This was done approx 3mths ago, fluid was flushed and checked and everything worked great.
Unfortunately I then had to go away so the boat hasn't moved for 6wks or so.
I have just got back and the engine is stuck in the up position. The motor is turning and seems fine. Battery good so enough power etc.
On inspection there are are no obvious hydraulic leaks-everything seems to be as it should be. The motor is just stuck up and i'm guessing this is through lack of movement!!
Does anyone have any ideas to free this.
My boat is in a saltwater canal and I cannot get it out as the lock gate is U/S until mid August!
Can I release the manual screw while the boat is in the water? Would this help?
Any ideas greatly appreciated
