luddovitch
- May 3, 2015
- 3
http://sv.tinypic.com/r/11qr6nd/9
Hey guys
I'm having problem with my old Yamaha 20hp 1981. When running at full speed my engine is loosing power after 1 minute or so and the water stream from the pee hole is almost gone. Then when I close the throttle the water stream is there again but with some white smoke coming out mainly from the exhaust but also some from the pee hole. I've tried it without the thermostat without any different results.
I recently changed the head gasket and the exhaust jacket (I think it's called) and made two homemade gaskets for the exhaust jacket, since the old exhaust jacket was rusted out and the engine was taking in water. I've checked the impeller and the impeller housing and it all looked fine to me, but the impeller housing was full of grease or something on the outside, not sure where that could have came from.
Here is a short video of the engine running in a barrel. I'm not sure if the water stream is good enough, it's more like a spray than a steady stream. Also note the grey colored water that flows from the exhaust, is that normal?
I didn't have this cooling problem when the engine was taking in water. The Engine is running good besides from this cooling problem, a bit hard to start when cold though.
Im I hope you guys understands my problem, my english isn't perfect..
Hey guys
