Yamaha 225 '96 No power
wethead1
I'm already kicking myself in the head so don't add to my misery please. I changed the battery and put it in backwards, after everything stopped smoking I reversed it. Now I have acc. power but nothing to my motor,volt meter or tach. How bad is it?::(
cousinabe
Re: Yamaha 225 '96 No power
check fuses. most likely they blew.
since you didn't post your full model number, i am guessing with this diagram...
http://www.boats.net/parts/search/Yamaha/Outboard/1996/S225TXRU/ELECTRICAL 3/parts.html
after that is fixed, check the rectifier output, simply check the battery voltage, then start the engines, run about 2000 RPM, voltage should increase by about 1 volt over non running battery voltage.
if its ok, ya got lucky, if not open the ole wallet.
wethead1
Thank you for the help, I'll check first thing in the morning
wethead1
Just wondering, if it's wort case, am I facing 2-3 hundred or 2-3 thousand?
