I have an 89 Yamaha Excel 225 that has lost rpm's and power. The motor starts fine, idles fine, and bogs down getting on plane. RPM's max. at 4400 - 4500 and top speed is about 12 mph below normal. I changed the fuel water separator, primer ball, helped some but motor still surges lower rpm's and overall speed. Checked compression with the left top and bottom cylinders at 110lbs, middle 130lbs; right top and bottom at 120lbs, middle 130lbs. I changed the plugs but have not run boat since. Should I be worried about compression differences? What should I look at next?
