i have a 91 yamaha 250 v76 salwater series. it was running poor. i rebuilt all the carbs and cleaned all the jets. after repair still running the same. fires right up, idles fine, runs fine out of the water. as soon as its in the water and under load it will not run. i can idle around no problem but as soon as i give it gas or go wot it falls on its face and dies. i was thinking bad gas from sitting, so i put brand new 91 oct and it did the same. any ideas or tests i could perform? my next guess is i dont have enough spark under heavy load. im new to this motor and looking for any ideas or sugestions. any commom problems with this motor? thank for you time.
