Yamaha 30 deo not fireing on bottom 2 cylinders
Ron Selman
I have the yamaha 30 deo, i cannot seem to get it to fire on the bottom 2 cylinders unless i choke it, and only then do they fire momenterally, has anybody got any suggestions please
Ray Neudecker
Re: Yamaha 30 deo not fireing on bottom 2 cylinders
You determine whether or not the cylinder is firing with the use of a timing light or spark tester. If it shows they are firing, then you need to find and repair the fuel restriction causing the problem.
