Yamaha 30hp leaking oil thru carb
Jonathan99
Hello , Im hoping someone can help with my problem regarding a yamaha 1995 30 hp outboard, the problem is when the outboard is in the tillted (Up ) position , it leaks injector oil through the carbs , mostly thru the bottom carb ( quite abit runs out actually) any ideas on a repair would be appreciated .
deejaycee_2000
Re: Yamaha 30hp leaking oil thru carb
Welcome to the forum ;) ..... rebuild the carb, new seals etc ....
