Yamaha 3hp revs keep going-up
Boating_Al
My brother-in-law has an Yamaha 3hp that we took out this weekend(Columbus Day) and we could not use it, it started fine?pulled the choke & give it a pull & started-up, but when the choke was pushed back-in the motor would start to rev-up like it was going to exploded.
Help?what it could be?the motor worked fine two weeks ago.
robert graham
Re: Yamaha 3hp revs keep going-up
Sounds like a problem with the throttle cable. remove shroud, operate throttle/carb linkeage for binding/problems. It should operate very freely, opening and closing carb. Good Luck!
Boating_Al
Actually the linkage operated just fine, we took the carb off & sprayed with carb cleaner (did nothing)?I?m thinking it?s a victim of ethanol. May have to rebuild the carb.
Thanks...
99yam40
has to be a stuck butterfly to be getting enough air to rev that high
