I'm in the process of buying an aluminum jon boat that I would like to power with a 60HP Yamaha 4-stroke. The boat is 18 foot long, has a 60" bottom, and a 82" Beam. The .100 thick hull weighs in around 1000lbs without the motor. It will usually have 2 passengers, 15 gallons of gas, 3 batteries, and and minimal fishing gear. I chose this motor based on weight, and my local service. If I upgrade to a 75hp or 90hp the weight jumps from 240lbs to 370lbs. With the gas, batteries, and passengers near the rear of the boat, I worry about navigating in shallows, as well as porpoiseing (sp?) if I go ahead and get the bigger motor. I'm also content with 30mph, which I'm guessing it can do based on the performance tests on Yamaha's website. My question is this:<br /><br />1. Does anyone have a similar set-up that can comment on the performance.<br /><br />2. Should I consider one of the high thrust models, even though this isn't a pontoon boat? It is a modified V hull (12degree deadrise). Not sure if this boat fits in the displacement category or the planing category.<br /><br />Thanks for any input!!
