1985 40 HP Yamaha. After hours of searching the threads I havta ask for help. I'm experienced with CDI ign trouble shooting but here's my dilemma. Engine will hard start but runs on # 2 only. Removed all spark plugs for spark test and only # 2 has strong blue spark. #1 & #3 will spark only once when the key is initially turned to start, after that one spark it's no show. I swapped the coil supply wires to see if I could "move" the spark and sure enough the good spark follows the #2 input wire (trigger, pulse whatever it's called) from the Black Box. So the Coils appear to be good. Next was the OHM Resist test. I tested all three wires from the Black Box to the coils and all 3 had exact same readings. Same test from the black box to the stator wires and all three wires had same reading. Could it be an alarm circuit or some other system telling the ign. to limit fire to only #2.
Any feed back on this is greatly welcome.
