yamaha 40hp rpms surge at low speed
brico
1991 yamaha 40 hp 2 stroke. Previous owner said engine sat for a while. Cleaned carbs, blew out fuel lines, replace fuel filter, gas, fuel pump, plugs Etc. Cleaned a bunch of crap out of the start primer pump which made a huge difference in performance( it was all gummed up from the diaphram sitting in fuel) diaphram needs to be replaced but no visual holes or tears, just looks a bit stretched (got one on order) engine runs like a bat outta hell at WOT, but when I kick it in gear at around 1000 rpm it ramps up and down. Idle is ok seems like the idle screw is adjusted in a little much (one more turn and it's down all the way) Not sure if it electrical or fuel. What am I missing?
Any ideas
