Yamaha 60 hp 2 cycle outboard.
OldTimer76
Needing info. on how hard it is to get parts for this engine. Told it is a 2004 thru 2006 year. The engine has 3- carbs on it instead of injectors.
robert graham
If engine is set up correctly and running well, then the parts you'll most likely need are water pump parts, spark plugs, etc.....I doubt you'll have much trouble getting parts for that motor anyway....
99yam40
does this motor have the id plates/stickers on the bracket telling what it is and when it was manufactured?
also where is this motor and / or you located.
USA or some other place in the world?
