yamaha 70 etlg (88)h20 pump
robdobdoo
does this outboard need a sleeve inside the h20 pump housing next to the impeller and does it have a key that fits in the shaft tahat turns the impeller?
Profittakr
Re: yamaha 70 etlg (88)h20 pump
Yes - there is a metal 'cup' that the water pump spins in. It is as tall as the impeller and slightly smaller diameter and the impeller 'squishes' into this cup to make a tight seal. This is underneath the plastic water pump housing. Your 2nd question is if the water pump shaft has a key on it to turn the water pump and the answer is yes I believe it does. I did not change mine this year but I am sure it does.
robert graham
If you buy the water pump kit, it comes with all the parts, new woodruff key, cup, gaskets, impellar, etc...get the kit and replace everything, only cost a few bucks more than "just the new impellar". Check: SIMYamaha-Andy's Tips gives step by step instructions with photos for water pump replacement, different HP motor, but the basics are very similar. Good Luck!
99yam40
The housing comes separate from the kit
