Yamaha 70b outboard
Hi Guys new to the site, having a problem with my yam 70hp over charging at 17.7 volts I have replaced the rectifier? and the battery but to no avail the yr is 1991 model 70b serial 6h3l477900
it took out my fuel gauge and sender along with my volt meter which i have now replaced and put on a sep switch to isolate until i can cure the fault, the motor is running ok and the tacho still working fine' could it be the charge coil or the lighting coil?? would appreciate any feed back
cheers
Dave
