Yamaha 75 HP 1996 - Buzzer
Does Buzzer Sound for any reason other than overheat?
Buzzer sounds when running a full throttle. Tell tail stream is strong and cold to the touch. I plan to replace the waterpump as a precaution but does the buzzer sound for any reason other than overheat? Engine feels to slow as buzzer sounds but runs fine at lower RPM. Help is greatly appreciated.
99yam40
Re: Yamaha 75 HP 1996 - Buzzer
low oil level will if it has oil tank
Might check or replace thermostat and PRV if it has one also while you are at it
I premix the fuel so I dont think its that. Does the buzzer sound only on overheat on these older engines?
99yam40
a model # would help everyone know what motor you are speaking of.
C75 TLRU would be a 1996 that was premix and overheat would be the only alarm on it that I know about
Model is Yamaha C75 T LRT - I will concontrate on the cooling system - Thanks for your help Captain.
