I understand that this is a difficult question to answer with limited information, but I am hoping to get a baseline here.
I bought a beater boat last week for dirt-cheap. Don't laugh, it's a 17' Bonito Tri-Hull with a 1999 C75 Yamaha 2-Stroke on it. For the price, it was worth it for the trailer and motor alone, which popped 120-125 PSI on all cylinders.
Problem is, it needs a new prop. There is a stainless three blade on there now that is so bent up I do not even want to run it once. Plus, it's also not marked and the boat doesn't have a tachometer installed to check anything with.
Can anyone give me a baseline idea for diameter and pitch so that I can go buy an aluminum 4-blade to put on it? I was going to go with the 4-blade because I think the boat is going to need a little bit of help with the weight....
I will eventually get a tach to verify, but I need a place to start and get the boat on the water.
