outdoorsman37
- May 28, 2010
- 25
Hello. I pulled off the lower unit and the screw that needed to be loosened for the shift rod broke and when i pulled the shift rod came off from the lower unit instead. so now i pushed the rod back in the lower unit and it when in twice but not the third time.
do i need to pull apart the lower unit to get the shift rod in or is there a way around it? it seems like there is a rid that moved to block the shift rod from going in there.
so, how do i get the shift rod clamp out and how do i get the shift rod back into the lower unit? thanks so much!
