i have a 1998 yamaha 90 hp 3 carb setup. i just bought the boat and it would only get to 4500rpm. i was told that it shuld get close to 5500rpm. i changed from a 19pitch to 17 pitch prop. now it will get 5000rpm and run 36 miles per hour . this is on a 17.2 foot keywest at aprox 1150 pounds i believe it should run faster about 42. my question is with it ideling at 1000rpm i can pull the sparkpulg wires off one at a time and the top and bottom cylender will cause a rough ideal. the center causes almost no change at all. i do have plenty of spark and did change pulg. but it stayed the same. if it had a bad cylender would it achieve 5000 rpm . and i also herd that i may not be able to hear or see a rough ideal with the center plug wire off. have any of you got any ideas for me or does it sound like it is ok. thanks much ..gayle
