2001 C90 Yamaha will slowly tilt/trim down while poling and running.<br />Problem is getting worse over last few months.<br />The trim/tilt otherwise works fine. No external fluid leaks visible. Level is not low.<br />No visible corrosion/problems on rams.<br /><br />Several of my friends with same or similar motors have noticed same problem.<br />I notified Yamaha customer service, they were "unaware" of any issues.<br />Local mechanic recommended against replacing just the seals, but entire trim/tilt assembly (part alone $900)<br />Another mechanic recommended cleaning and replacing all the seals (parts 100, 6 hrs labor @ 85 $/hr) <br />Any thoughts?<br />Thanks<br />Dave
