I HAVE A YAMAHA 60 hp THAT WILL CUT-OUT AND NOT ACCELERATOR OR EVEN PLANE WHEN UNDER A HEAVY LOAD.<br /><br />THE ENGINE WILL CUTOUT AND ACT LIKE IT IS STARVING ABOUT 50% OF THE TIME WHEN 3 OR MORE PEOPLE ARE IN THE BOAT. IF YOU CONTINUE TO MILK THE ENGINE AT 3/4 THROTTLE FOR 2-5 MINUTES IT WILL WORK ITSELF OUT AND THEN BE OK FOR A WHILE. IT YOU PUSH FULL THROTTLE WHEN IT IS DOING THIS IT WILL COMPLETE CUT OUT, SHAKE AND DIE OUT. IT WILL THEN BE HARD TO START AND NOT IDLE RIGHT FOR 15-30 SECONDS. THEN IT WILL BE FINE FOR A WHILE AFTER IT DOES THIS. DEALER SAYS NOTHING IS WRONG, BUT OF COURSE THEY DON'T PUT IT IN THE WATER WITH 3 OR MORE ADULTS.
