cptbill
- Oct 6, 2012
- 762
I know this subject has been around before but I have a question that needs another opinion because I've debated myself so much that I lost all sense. Twin 2006 Yamaha 250 4 stroke I'm going from 2 batt. to 4 batt.(I know over kill, more weight, etc.)I want to use the Aux charging ports for the 2 house batt. so when I pulled the 2 battery switches off I found that that the Aux where connected to the main posts in the switches so that means that the main engine battery cable and the Aux. wire are both charging the same battery (both engines, 1 Aux. ,1 main on the same post on each switch. This seemed kind of funky to me so now I've been way over thinking why? My goal is to let the main cable charge the starting batt. and the Aux. charge the house batt. All 4 battery's charging all the time(running on the start batt. and the house is still being charged. my question is am I thinking this is correct. I also have a simple on/off switch to run between the to main switches just in case.
