Yamaha compression test ?
9989
Would this be the right way to do a compression test on 1989 Yamaha 225 excel with YMIS computer ing. and three carberators. Run engine until warm, remove spark plugs, throttle wide open, manual says to ground all spark plug wires to engine but can i just remove kill switch tether to disable ingnition system. If not what is the best way to ground spark plug leads. Would appreciate any advice.
mcfly99
Re: Yamaha compression test ?
Kill switch tether grounds the ignition, removing the tether should work fine.. That was the same procedure I followed with my engine for a compression test.
