Re: Yamaha EFI Question
rodbolt,<br /> Please evaluate this comment from THT regarding an O2 sensor and failsafe:<br /><br />"HeadHunt - you could not be more wrong. If no output from a failed O2 sensor is seen by the ECM, the system will stay in open loop condition, which is the same as when you first start your car, until the O2 sensor is heated up enough to start sending the voltage fluctuation based on O2 content to the ECM. Once the O2 sensor is heated up enough to send a voltage fluctuation to the ECM based on O2 content in the exhaust gases it then goes into closed loop mode. This is where all sensor input is used to calculate the fuel and spark curve to meet the condition. So It's not a fail safe mode but in open loop condition the engine is running at some predetermined fuel and advance curve as setup by the intial program in the ECM. This by the way is a rich conditon as opposed to a lean condition. An O2 sensor when it goes bad sends no recognizable voltage swing output, something other than .1V to .9V swing. A failed sensor will either send no output or a constant .45v to the ECM, this is considered the midpoint which is neither rich or lean, and no oputput will keep the ECM in open loop mode. A constant midpoint voltage of .45 is recognized by the ECM as an incorrect value, so it stays or reverts to open loop mode.<br /><br />So to answer the quesion correctly a bad O2 sensor on the OX66 Yamaha outboard will keep the engine in open loop mode which btw is a rich conditon, and it will not burn a piston. Anyone that says it will does not understand the theory of the O2 sensor. This BTW is why when an 02 sensor goes bad usualy carbon fouled in an OX66 engine, you will see more smoke, and the engine is not burning at optimal air/fuel ratio of 14.64:1, but something higher. Therefore you will loose rpms!<br /><br />don't know where you are getting your facts from, but no one is talking about failsafe but open loop vs closed loop. The ECU in order to change the mapping needs a voltage swing! Not a constant voltage, a constant voltage is considered incorrect! When an O2 sensor goes bad it either reverts to constant or no output at all, the ECU will not recognize a constant as a legit input and revert to open loop. I know this for a fact because I was on the development team that designed the Chrysler technician diagnostic terminal which was formulated based on sensor technology. It's the same for all engines since OBDII is a common system. Yamaha uses the same methodology! <br />BTW - the statement you refer to is a statement based overall on a lean condition, not on the O2 sensor theory! Which was very evident on engines that are carbed. If a carbed engine has fuel delivery problems either from a blocked jet or bad fuel pump, you will get a lean condition! The same goes for an injector failure on the Ox66! <br />I agree with only part of your explanation that going to the higher value is to signal more lean. But the ECU has to see voltage swing in order to stay in closed loop mode! <br />Believe what you want but your information is not entirely correct. So if your facts are correct please help me understand why when an O2 sensor goes bad you see more smoke and less rpms! Reason being it's running rich!"<br /><br />rodbolt, this discussion got going about O2 sensors going bad and would they potentially blow pistons. One guy offered the above explanation. Sound accurate??<br /><br />HH
