Have a 1995 200 TXRT outboard
Engine was running fine. I was out fishing and all of a sudden the engine went into ?safe mode?, would just idle and not take gas. The engine was still spraying water through the block, no warning lights but a buzzer kept going off. Slowly I got the boat home, checked the compression and had between 112 and 120 in the cylinders. Took out the thermostats, reset the computer with the little toggle switch attached to it off I went. The engine will idle just fine but as soon as I give it gas, it goes into safe mode. I am not afraid to get into the repair end of it so if you can give me some ideas, I will give it a try. Whatever you suggest, give me an idea where it is located on the engine.
Thanks
Gene
Thanks
Gene
