Yamaha F115 starting problems
Pas Bon
Second time this has happened.
Running along and quickly slow down and shut the motor off. Try to start it and it cranks but will not start? try about 10 times wit a few minutes then it fires right up and can be shut off and restarted.
Any link between quick shutdown followed by startup failure?? This is a 2001 motor with low hours
99yam40
Re: Yamaha F115 starting problems
Yamaha manual says to run at low RPM for few minuets to cool motor down before shutting off after running high RPM for awhile
Pas Bon
May very well be the culprit...thanks
