sutor623
- May 23, 2011
- 4,089
Hey guys,
Got a 2006 Yamaha F115 (fourstroke) and the trim motor will work 75% of the time. The other 25% I have to tap the motor with a hammer and it will work fine. The relay is engaging when the motor decides not to work. I was wondering 2 things.
1.) Can you tear these motors down, clean them up and rebuild them?
2.) In order to remove the trim motor, will I need to drain the hydraulic fluid, or is it contained regardless if the trim motor is installed or not. Thanks!!
