Since I have installed my new Yam F150 engine I noticed some strange noise with the trim/tilt.
This happens when the engine is in the full low position, while tilting it up there is a strange noise with the two small cylinders rams until the main cylinder enters in action, then normal noise, or when the engine is in the full up position standing on the stop lever and retracting the two small cylinders rams, strange noise, then extending them, normal noise.
I have followed the bleeding procedure from the service manual (which despite of tons of useless warnings does not mention that this is an operation that is difficult to perform alone due to the weight of the engine), the trim works well but still the noise remains.
During the procedure I saw some hydraulic leaks on the two small cylinders, strange since the steals have been changed just before I bought it, I don't see this leak in normal operation, normal?
I have noticed in some Yam youtube videos the same noise, is this a normal noise or what? My former Yam trim/tilt did not do this noise.
