Yamaha F225hp Flushing Question
vandad
Hello my friends - I have a question regarding flushing the F225 - I usually use the muffs and leave the engine running for 5-10 min but the new marina which I am going to take it to makes it quite difficult to flush (no rear pontoons) so I tried flushing it from the adapter hose from the fitting on the bottom of the cowling but I noticed all the water is coming down the legs (next to prop) and no water comes from the telltale hole. - Is this normal?
boscoe99
Re: Yamaha F225hp Flushing Question
It is not abnormal.
Turn the pressure up. Use a bigger hose with less length. You can get it to pee from the tell tale but it is not easy using the garden hose fitting.
