Yamaha F25TRLY 25 HP 4 stroke year Voltage Regulator Question.
TTravis
I think I blew my voltage regulator while revving my engine. Not too much rev, but
I was testing my cab after I cleaned it.
My main fuse blew, and another when I replaced it.
I got my ohm meter and saw that indeed something was shorted to ground.
I traced it to my voltage regulator and removed it. Sure enough I measure 0 ohms
from the red lead to the body of the regulator. Someone please correct me if I am
wrong, but I believe that means it is bad.
The numbers on the regulator are 854414 and 2888.
When I google 854414, I seem to turn up a lot of results for CDI Mercury Voltage Regulator
and the picture looks the same.
Looks like this may be a fairly common part and the price varies from around $150 to $200.
Anyone have a suggestion for a good source?
Thanks,
Tom Travis
TTravis
Re: Yamaha F25TRLY 25 HP 4 stroke year Voltage Regulator Question.
I ordered a new regulator/rectifier. Hopefully that will do the trick.
99yam40
Only reason I can think of for overreving causing problems is something coming apart. maybe the lighting coil had something get into it
You should never rev a motor in neutral
