Yamaha F60 Trim Tilt
Shott
I recently changed the motor for my trim tilt unit because the top housing was rusting pretty badly and I did not want it ti spread to the rest of the unit. It worked fine before but now it will not move. The motor makes noise on the up and down but the piston does not move. Do I need to bleed it at this point? If so, where can I get directions?
Yamajoe
Re: Yamaha F60 Trim Tilt
When you attached the motor, did you insert the O ring?
kmontgomery1
Re: Yamaha 50 four stroke
we have a 50 on our boat, engine runs great, but the trim and tilt is not working, any ideas?
G
Guest
Guest
Some details would help. Does it go up or down...any noise, is tilt motor running...using switch on console or on motor body...etc.
