Panama Ron
- Mar 18, 2008
- 2
I have a 2005 Yamaha F75D fuel injected outboard. Recdently had a problem of cutting out and sputtering at higher RPM's which I believed was a fuel problem. When I backed off to about 2000 RPM it settled down for a while then quit. The engine would always start right back up afterwards. Thought is was water in the fuel. Did not have a fuel seperator so ordered one. Then disconnected the built-in tank and installed a portable 6 gal tank to eliminate that possibility of water in the fuel tank. Ran OK for 1 week then same problem. Checked the fuel filter after it shut down, still had full fuel and no water in the bowl. Replaced the squeeze bulb and fuel line after a small leak found. No change. Checked all wiring and sensors, no problem found. Changed oil and filter thinking something was clogged causing the engine to shut down.
Only thing I can think of is the fuel pump, but I really know very little. Any of you "smarter than me and way more experienced" guys have any other ideas? I am stranded on an island in Panama!!!!
