Yamaha FT60BET Replacement Trim and Tilt Motor and fluid/oil
twr7cx
Anyone able to assist with the correct part number for a replacement Trim and Tilt Electric motor to suit a Yamaha FT60BET (4 stroke) outboard?
In addition, what is the recommended fluid/oil to use in the hydraulic ram system?
twr7cx
We've ordered a replacement aftermarket electric motor for it online, waiting for it to arrive. It's a bit different in it's style but looks identical where it counts - mounts, bolt hole pattern, shaft size and length.
Still need to get some fluid for it.
99yam40
Yamaha service manual should give this info, do you have one for your motor?
I do not have that motor so I do not have nor need one.
seems like I remember Decron III trans fluid was listed for my old C40
