Yamaha Guages Back lighting
Brian Kiwi
Can anyone tell me how to ajust or (Turn on Turn off) the back lights on my Yamaha Guages.They are for the latest model 4Stroke 115.Thanks Cheers.
64osby
On my boat the gauge lights are hooked in the the anchor light circuit. When ever the anchor / running lights are on so are the gauges.
Do your lights come on at all?
Brian Kiwi
Its ok now. I have had help from another boating Forum and the problem is solved.Many thanks for your input.
Seon
For future reference to others with the same question, there?s a yellow and blue wire in the middle of the Power/tach signal harness.
  • If the yellow and blue wires are connected together, then the back light will come on when the ignition key is turned on.
  • If the blue wire is connected to the Navigation light switch, then the back light will come on when the light switch is turned on
