Yamaha heat sensor
woodsailboat
I have a 1992 200 HP 2 stroke yamaha and the over heat sensor keeps going off and I need to know if the sensor is bad or if just one cylinder is block from getting water or if I have something worse going on but I am positive that the impellar is working and the water that comes out of the motor is cool. please help
99yam40
Re: Yamaha heat sensor
You can pull sensor and test it to make sure it is really seeing the overtemp, but if it is functioning within specs then you have a real over heat happening.
Possible cooling passages plugging, lean running cylinder, or pump problems.
If it is happening at low RPM then possible PRV sticking
woodsailboat
Is pulling the sensor something that I can do or do I have to take it to a mechanic.
