HI all knowing gurus
I have an overheating problem with 1986 mariner/yamaha 40 hp serial 6E9 [ mariner 2 cyl 2 carb built in japan by yamaha] We have good flow from teltale but overheats in around 10 mins at half throttle. [Steam & way too hot to touch] Checked t/stat and PRV seems ok so tried to run with T/stat cover removed to check flow - no flow at T/stat exit hole and exhaust pressure at PRV seating. Something not right here - exhaust in the cooling passageways ??? Should there be water flow at open t/stat housing ??
What is the normal flow of cooling water around the engine from the impeller pump? prevoius owners hinted at cooling problems and I suspect some blocked passageways in the head/jacket - How best to clean out - muriatic acid ?
Is there a t?stat bypass on this model?? - how to pinpoint problem??
thanks to all on this forum who spend time to help
over to you Redbolt
over to you Redbolt
