jerryjerry05
- May 7, 2008
- 18,110
Working on the oil system and need to know how it works?????
The tank under the floor has an electric pump and a switch on it (motor) to feed when the tank on the motor when low.
Isin't it supposed to feed when the motor runs?
What sender sends a signal to the pump to feed the tank on the motor??
The tank(both) and lines were clogged with algae or white muck.
I cleaned them out and put in new oil(threw out the old) and flushed the lines.
Any literature on this??
This is the 3rd Yam in 1 year I've worked on with the oil algae growing in it.
I heard diesel fuel and some oils can grow algae or the sludge??
Thanks, Jerry
