Yamaha Precision Blend questions
Big.Band
Hey everyone - I've been 'lurking' on this site for a long time, and finally need some help.
I've purchased a 1992 30hp with "Precision Blend". The guy I got it from was using gas/oil mix in his fuel tank, but the on-board oil tank has oil in it. He only had the motor for a short time, and didn't know much about the precision blend system
I figure that either the precision blend system was not working, so he pre-mixed his fuel, or if the system is working, his motor was getting double oil.
- How can I test the precision blend system to see if it's working?
- I assume there is some kind of 'low oil' warning system?
- What is the best source for an OEM manual for this motor? Anything available for free download?
Thanks !
Mark the oil level in the tank.--------Run the motor on 50:1 and see if oil level drops.-----Or see if oil drips out of the wee hoses from the pump.
Doh
The Oil Level Sending unit is in the tank, attached to the rubber plug with 2 wires coming out of it. It is just a float that could be fooled so that the tank wouldn't need to carry oil.
It is a pretty fool proof system, I cannot see Why the pump would stop working.
Big.Band
Pardon the newbie question, but what's a "wee hose" ?
Also, does this motor want 50:1, or 100:1 ?
robert graham
It should go without saying that until you determine the operation of your oiling system then pre-mix your gas/oil at 50:1 ratio....it won't hurt the motor if there's extra oil....just maybe more smoke...
Big.Band
That makes good sense, thanks for the clarification.
Is there any source of free OEM service manuals out there in the internet?
Sea Rider
Yea! The on-board oil pump is working fine. Thanks everyone!
Much better, lower, middle rpm ranges requires way less oil than running 50:1 mixture constantly throughout the whole throttle range. Spark plugs will work better and stay cleaner longer.
Happy Boating
