Yamaha pro 50 limp mode?
pa312d
1991 yamaha pro 50 p50tlrp
Just recently bought this boat went out twice and it ran fine, and on the way back in it went into a limp mode of sorts. my buzzer was not going off either for overheating or low oil. any ideas?
99yam40
are you sure the buzzer works? do you have any gauges that will tell you anything?
pa312d
unfortunately no my boat is a tiller setup and has no gauges. any idea how i could test the buzzer? the maual doesnt say. i checked and i have spark on all cylinders and the plugs are a good color.
99yam40
Not sure if a 91 50 tiller would have a buzzer, so you need to be looking at both overheat and low oil to rule them out
pa312d
i do have a buzzer. i disconnected it and hooked it to 12v, it clicked so i persuaded to work again. so its buzzing when the key is on and if i unground my oil level unit it stops buzzing. so im going to do a resistance check in the morning.
