Re: yamaha remote oil tank installation
I found the harness plug and got the pump wired. When I turn the ignition switch on, the pump runs about two seconds then turns off. When I trigger the low oil sensor in the primary oil tank on the motor, warning signal goes off at the gauges but pump does not come on. Am I missing something? Thanks.
