Yamaha Speed & Fuel Manage Meter
benniebgh
I have a Yamaha Speed & Fuel Manage Meter (6Y5-83500-40-BK). I am having trouble figuring out which wire from the meter connect to what wire on the boat.
Is there another wiring harness from the meter to the key switch that I need?
Is there a part number for such a harness?
Regards
Benniebgh
rodbolt
Re: Yamaha Speed & Fuel Manage Meter
yes, you need a fuel flow sensor for each engine and the harness between the sensors and the FFM. sender 6y5-85752-01 and wire harness 6y583553-f1 should do you. the rest is mostly plug and play.
the white meter lead will go to your fuel sender which on the hull wiring should be pink.
NOT the pink on the yamaha wiring.
the information is in about any yamaha rigging guide from about 2000 to presant.
