ARCHSEA BUNKER
- Mar 6, 2009
- 50
I Removed The Four Wire Connector From The Remote Tank And Tested Continuity Of The Wires From The Connector Back To The Connector Inside The Engine Cowling.all Tested Good.i Checked The Brown Wire For 12v.nothing.i Then Peeled Back The Harness And Followed The Brown Wire.it Went To A Three Wire Connector Of Which Two Wires Go To A Trim Switch.the Brown Wire Was Not Used It Just Went To A Blank In The Connector.i Though It Was Supposed To Be Hot With The Ignition On.it Its A 2001 Model.the Oil Pump Will Work If Connected To 12v.alrm System Will Sound If Oil Is Low.
