yamaha tilt and trim will not raise
seahawk108
hi i have a 1994 90 hp yamaha went for a ride and trimmed up worked fine, went to trim up a second time it will not do anything. motor will run when i press the button to lower but will not do anything when i try to raise
help please thanks seahawk108
rodbolt
Re: yamaha tilt and trim will not raise
you have two circuits, one is trim control, at the trim relays you will have a blue 10 Ga and a blue 18Ga wirethe down relay is the same only with green wires.
jumper ,one at a time, the small blue and green control wires to a 12v source.
if it works you have a control problem, next the simple test is to swap the location of the 10 Ga trim motor wires and see if the problem changes.
do a foruim search on Trim Relay testing. if ya cant find it when I get some time I can repost it.dou you have a multi meter ?
seahawk108
thanks, yes i have a multimeter, i'll give it a try and get back to you
seahawk108
thanks a bunch for the info, i did what you said and found that the switch had gone bad.replaced the switch works great. thanks again
jamaica whaler
Hello,
I'm having the same problem, just found it out today, although my up trim will work after pressing switch a few times. I hear the clicking on the engine when using either trim on throttle or on motor so don't think its a switch problem. After a few presses, it works until switch is released. down works normally.
Could this be relay related, intermittently?
Would love help on this please!
thanks, jamaica whaler
