yammmy 115 sluggish out of the hole
cpj
Ensign
Gentlemen,<br />I have a 1985 115 yahmaha etlk outboard.Problem is out of the hole (or loading it on the trailer)it sputters and sometimes dies.But if you ease into it, it runs fine at top rpm and every where in between.I just rebuilt the carbs,fuel ine is good,fuel filter is new, plugs are new.Now this problem just appeared one day with no other symptoms.(and after the afforementioned parts)Fuel pump maybe??? Havent checked fuel pressure yet,What should it be?Thank you in advance from a newbie!
Ray Neudecker
Re: yammmy 115 sluggish out of the hole
Likely to be the fuel pump. Also do away with the fuel line disconnect and run hose direct as Yamaha has done on the later models.
cpj
Ensign
Thank you Ray!<br />What should the fuel pressure be??????? :confused:
