Yammy 90 vs 115
NBE
I know this is kind of a general question with each motor probably having several models. <br /><br />For freshwater use, are there any differences other than horsepower, that would make any of you choose one over the other? Reliability, maintenance issues, quirks, replacement parts costs, etc.<br /><br />Have the opportunity to purchase either motor (each with a boat which is an issue on its own) that are 2003 models. Besides the usual prechecks that will be done, i.e. compression, etc., I was just curious to see what is the general opinion of each of these motors from people on this board. <br /><br />Thanks!
JB
Re: Yammy 90 vs 115
They are very different engines.<br /><br />The 90 is a 3 cylinder inline, light for a 90 and highly tuned to get 90hp from only 70 ci. It will use less fuel and be anemic on hole shot compared to the 115.<br /><br />The 115 is a V4 of about 105ci. Heavier with LOTS more torque at low and transition speeds. It would be thirstier.<br /><br />Both are very reliable engines. Maintenance and parts costs are in the same ballpark.<br /><br />Which to choose? That depends entirely on what boat and what priorities it needs to fit.<br /><br />Good luck. :)
NBE
Re: Yammy 90 vs 115
Thanks JB!<br /><br />That is pretty much the type of info I was looking for. I know not much about Yamaha motors other than people I know who have them do like them very much. I've been mostly a Merc man over the years but am not against trying out the Yammies.<br /><br />I guess we're probably talking about roughly a couple of gallons or so per hour gas consumption difference at WOT between these two motors from what I've read on here. <br /><br />I can live with either one (boat and motor) so I guess it will be whichever package is the best deal and/or motor checks out the best. <br /><br />Thanks again for the info! Any other opinions out there?
jameservin
Re: Yammy 90 vs 115
Every local mechanic I have talked with said go Yaamha. I bought a merc 90-why? Im frugal and saved several thousand. Figure the merc's "good enough".<br /><br />Time will tell.<br />Good luck.
