year of evinrude motor
mrtzdvl
Can anyone help me to diagnose the year of this motor. It was given to me and I need to do some work to it but I need to know the year so I can get the right parts.<br />Serial number on unit is as follows: 15020-26538.<br />Any help would be appreciated.<br /><br />mike.
MGuckin
Re: year of evinrude motor
If you know the hp, search will be easier but this link should help. Click on docktalk after clicking on this link. <br /> http://www.evinrude.com/ <br /> :)
E R Pearson
Mike. If you have not got the info on your Evenrude yet my listing for 15020 says that it is a 1957, 18 hp.
mrtzdvl
thanks for the quick response. It appears to me that it would be a 1957 model. If anyone knows anything about this year please email me and let me know the heads up. Again thanks.<br />Mike
Chinewalker
Hi Mike,<br /> Your '57 18hp is a good old motor. It is basically a bored out 1956 15hp, as they upped the cubes by a couple for 1957.<br /><br /> To start with I would run a compression check - you want both cylinders to be somewhere above 100psi and within about 5% of each other. <br /><br /> Most of the maintenance and tune-up items are still readily available at a dealer or through NAPA. If you're unsure of the motor's service history, it wouldn't be a bad idea to replace the waterpump impeller, hoses and condensers.<br /><br /> Check to make sure the points are clean, and if the coils have a shiny plastic covering. If the coils appear cracked or the plastic looks chalky, replace them. For under $100 you can do a top-to-bottom tune-up that includes resealing the lower unit - don't forget the shift rod o-ring. It's a fairly easy motor to work on and a strong runner when done. <br /><br /> Be sure to feed it a steady diet of 32:1 fuel/oil mix (1 pint oil per four gallons gas) using top quality TCW-3 rated oil and good quality gas - I prefer 89 as it's generally more consistent than 87. There's no need to run high test in it.<br /><br /> I've got a few odds and ends for those 18s should you end up needing the odd part or two.<br /><br /> Above all, have fun!<br />- Scott
mrtzdvl
Thanks to everyone who posted replies. I will probably have more questions listed elsewhere concerning this motor and one other.<br /><br />Thanks again,<br />Mike
