Yellow stator leads
PB48052
1976 20 hp Merc
What is the proper unregulated/unrectified voltage output for yellow (battery charger) stator leads?
PB48052
These yellow leads are for battery charging, they would have to be over 12v, probably more before regulator and rectifier
emckelvy
I've seen 100V+ on an unloaded outboard stator, revving the engine. I don't recommend holding onto them and doing that! Obviously there's a point where the stator would develop so much voltage that potentially it could exceed the insulation resistance value of the windings, and Zap there goes the stator!
The main concern on a Merc charging stator is to check the resistance and if it meets specs, it's probably OK. Check the leads' insulation for cracks, etc and repair as needed.
Now, when the stator is hooked up to a rectifier and loaded-up with a battery, that's a much different thing. The stator is rated for around 10 amps output, and this is dependent upon rpm (the old, unregulated-style of electrical generation).
An old unregulated charging system can be upgraded with either a separate voltage regulator, or a combination regulator/rectifier, which is what was used on most of the larger, later-model Merc outboards. This provides a much more stable voltage for sensitive instruments. An unregulated system can potentially drive battery voltages up to 15 or 16+ volts.
If you're just using the electric start on the motor and have no other electrical loads, you really don't need the regulator unless you're using a special-type battery. The old lead-acid batteries usually work OK with the unregulated system, but newer ones, such as the AGM-type, may not tolerate it.
Well, that's a lot more than your original question asked, but there it is!
HTH & have fun................ed
Faztbullet
Depending on RPM anywhere from 10-15 VAC is correct as its a 4 amp stator.
The stator puts out AC voltage which is rectified into DC voltage for charging, DC output will be around 13.3 VDC at WOT
PB48052
Thank you, Mc Elv,
it's a 1976 20 hp, just want to have nav lights and bilge pump. Motor was bought used and I went thru it, starter missing, but all else in place. Needed a voltage threshold for purchasing or making bridge diode.
Also, among many others, I just acquired a 1964 110, 9.8 hp and need BTDC piston height for WOT, dial indicated. Seems like .461" or .463", but I've forgotten and cannot locate specs
emckelvy
It does make sense that the smaller stator will put out less amps than the larger outboards. But 4 amps should be plenty for your lights, etc.
Here's a well-build bridge rectifier on eBay that you could easily adapt to your charging system:
http://www.ebay.com/itm/281275599199
This is not internally grounded as is the Merc rectifier, so you'll need to run a separate jumper to ground for the negative terminal on the rectifier.
There are cheaper ones on there ($.99!) but they come from Hong Kong and delivery time will be longer. The one in the link mails from the U.S.
HTH............ed
PB48052
Anybody get timing info for my '64 Merc 9.8? Made a pointer in my shop, but looking for a degree card/disc/wheel that sits along edge of Phelon ignition rotor plate.
BTDC piston height would be helpful.
