This is a 1980's gamefisher tri-hull
Im trying to figure out the best way to fix this. How far should I cut this out?. The transom plate was hiding the damage. Im still thinking I want to use the plate because I want to go up to a 10-20 hp motor from the 7.5hp I have on it. The boat is able to take up to a 25hp. How many layers of wood should I use? Any idea's would be helpfull.
This is the plate that was on the transom just reversed.
