Yukon
coresuper
Would a regular size GMC Yukon with a 116" wheel base, 5.3 L 4WD with tow package sufficient enough to tow a 24' pontoon for a decent distance? Boat on the trailer is a good 30'.
bruceb58
Re: Yukon
Weight wouldn't be an issue at all. Might be a little squirrely in a cross wind. I tow both my boats in my signature with a 1999 Silverado 5.3L. The Wellcraft weighs way more than your pontoon and is probably just a bit shorter in overall length. My wheelbase is 143" so that is the huge difference between our vehicles.
tomdinwv
Re: Yukon
Pulled my 30' camper with my 2012 Silverado with the 5.3. You should be fine with the pontoon. Like Bruce said, just watch the crosswinds.
coresuper
Re: Yukon
I am more concerned with the shorter wheel base than the weight. I should have mentioned most towing is an hour or less. Maybe once or twice a year on the highway for trips.
bajaunderground
Re: Yukon
We just got a GMC Yukon Hybrid (Max towing 6,000lbs) tows the boat like it's not there and the camper (GVWR of 4,900lbs) it also does just fine, but the suspension sways more than my little 2007 Toyota Tacoma DC 4x4 TRD Off-Road. Not unmanageable, just not as well planted.
Leaf vs. Coil/with a 5-link control arms suspension. I believe the 3/4 ton XL's (Suburbans) have leaf springs?
I believe your towing capacity is 8,500lbs (with factory hitch) should tow excellent!
dingbat
Re: Yukon
You will have no problems.
My boat and trailer is 28' long and weighs #5.5k plus depending a fuel load. Hardtop and full curtains so the frontage is as much if not greater than your toon.
Up and down I-95 (Philly to Richmond) on a regular basis. No problems outside the usual 6 lanes of traffic running 80 mph then slam on the brakes, then do it all over again.
Not a fan of pickup trucks when towing. Not enough weight on rear axle
bruceb58
Re: Yukon
That's a trailer tongue weight problem then. With my boat, I have so much weight I need a weight distribution hitch.
dingbat
Re: Yukon
Not sure what tongue weight has to do with a lack of traction.
The Tahoe is roughly#800 heavier than a pickup. Assuming a 60/40 distribution, your looking at an additional~#480 on the rear axle. Anyone that drives a pickup in the snow knows exactly where I'm coming from. The additional #480 on the "traction" axle makes a big difference on the trucks ability at the ramp.
briangcc
Re: Yukon
Not a fan of pickup trucks when not towing. Not enough weight on rear axle
There I fixed it for you.
I'll agree that the rear ends on the Pickups are light when not loaded and it shows in the snow. However I will disagree with you when they are properly loaded or towing - they have as much traction as a SUV and don't suffer rear end sag to the extent that a SUV would.
I'm on my 4th Pickup and wouldn't hesitate to use one again as they are far superior, for my loads, than a SUV would be.
bruceb58
Re: Yukon
You never stated that traction was your reason.
The Tahoe is only 350# more than my extra cab Silverado pickup. Never had a problem on any ramp with traction if that's your main reason for SUV vs a pickup.
I used to tow my Wellcraft with a 3/4T Suburban. Other than the difference in power between the two vehicles, towing and launching is identical.
oldjeep
Re: Yukon
Kind of a generic generalization - modern pickups, especially short bed crewcabs have quite a bit of weight on the rear axles. Mine is 55%front/45% rear
bruceb58
Re: Yukon
OP didn't ask about PUs so we are we now way off topic.
jkust
Re: Yukon
So if you are a GM guy (or even if you aren't) and not into trucks, what's left except the slightly longer Suburban? I'm thinking you will be as good as can be suv-wise. As OldJeeps schooled me recently, the new 5.3's are actually a lot more powerful than even a few years ago...and even with a lower powered version of it I'm betting you will be fine.
dingbat
Re: Yukon
I thought you have a 2WD truck?
The primary use for the Tahoe is a beach buggie. The combo of short wheel base and weight make them just about unstoppable for an experienced beach driver. Nothing better on the beach except maybe an old full size Blazer which are just about impossible to find anymore.
Outsider
You cannot tow something that large without a diesel dually super-cab and electric/hydraulic trailer brakes! OK, back to reality. I heard many of the same' problems' I could expect before trying to pull a 24' Albemarle with an ' 01 Tahoe. The transmission was always the weak link with that era 'Hoe', but mine had already been replaced, and a temp gage added to the cluster. Weights are well within design specs of the vehicle, the trailer properly set up, and speeds appropriate for conditions. I do not have anything more than moderate hills, and might not be as satisfied if I did. The 'Hoe does just fine, and behaves very well under heavy braking. I had to call GM to find a CGVWR for my vehicle, and discovered it wouldn't be hard to reach the 13k limit. The tow/haul changes only the shift points of the transmission, and the speed OD kicks in (60 for mine). And my cruise control is squirrelly. I cannot use OD without 'hunting', so I tow in 3rd. Your Yukon will be just fine, up to a certain weight and with a properly set up trailer, that is. Length is not much of a player, but effective trailer brakes is. Stability will be fine as long as your tongue weight is appropriate to the weight (and behavioral characteristics when underway). The first thing I would do is weigh the combo to include tongue weight, so you start from a position of real numbers and not guesses. Make sure your hitch isn't overloaded by trailer weight (most are 5000# limited). Keep your speeds appropriate for the 30' of stuff behind you, practice sharp stops somewhere other than a crowded highway so you know what to expect (and change/adjust). Do not encroach on weight limits, the best that can happen is nothing, everything else is not good. And if the vehicle seems to be laboring, it probably is ...
