2001 200 hpdi died while idling (after running at cruise speed for 30+ minutes without a hint of trouble), will spin but won't start, not even a cough. No spark (discovered after changing out all the fuel filters). Kill switch seems OK (no continuity with clip in/continuity with clip out), gauges work, neutral switch tests OK, I changed out the fuse holder after both relays seemed to fail repeated continuity tests as specified in the service manual (though I was skeptical about it), still no luck. Any ideas about something simple? Might it still be the ignition switch? How do I check that? Thanks.
