Zercom flasher sensitivity control needed
David6545
I have a Zercom LCD flasher in the dash of my 1994 Stratos bass boat. The flasher was in the boat when I bought it in 1998. I damaged the on/off switch/sensitivity control while replacing a steering cable. Where can I get a replacement part?
xtreamfish
Re: Zercom flasher sensitivity control needed
David, Have you had any luck finding a sensitivity switch.... I have the same delma...Tyler
bruceb58
Since the last time the OP was on here was April 2010 and he only posted once, not likely he is going to respond.
I would start a new thread if I were you.
olso3657
There is one of these switches listed on eBay right now. Hope this helps.
Silvertip
Sensitivity controls are potentiometers with a specific resistance range. Some include a switch while others don't. Radio Shack or any electronic supply house can provide a replacement potentiometer but you would need to know the resistance range. That may be stamped on the part. You could wire in a separate on off switch.
